installing harmonic balancer hub??
Old Dec 17, 2004 | 12:59 AM
zcarguy's Avatar
Default installing harmonic balancer hub??
Ok,
Whats the secret to installing the harmonic balancer hub. I've already busted one bolt trying to do it without anti-sieze and tonight I think I may have stripped the threads in the nose of the crank doing it with anti-sieze. I know for sure the bolt is stripped. It appeared that the hub was going on and then got tight so I crank on the bolt a little then backed it out to make sure it wasn't over torqueing and found the tip of it stripped.
I bought an installer tool that said it was for small and big block chevy's but the stud on the end of the threaded shaft is to short to thread into the crank through the hub.
Any suggestions!!!
ZcarGuy
Old Dec 17, 2004 | 02:09 AM
00Z-28-LT1's Avatar
what kind of balancer is it.....i have a superdampner and i had to get the hub honed out so it would fit
Old Dec 17, 2004 | 05:56 AM
DietCoke's Avatar
Get a longer bolt. I put mine on with a piece of PVC pipe, a flat piece of wood, and a large hammer, then cranked it on with the bolt once I got enough thread engagement (you want at least five whole theads)
Old Dec 17, 2004 | 07:22 AM
BRENTT94Z's Avatar
It needs to be tapped on w/ a rubber mallot and dont use the crank bolt next time to crank it on youll strip the threads every time. The hub needs press on atleast 3/4 of the way before you can Install the crank bolt. At that point you can run it down the rest of the way w/ the bolt.
Old Dec 17, 2004 | 07:27 AM
FIREHAWK #07's Avatar
i also used a rubber mallot, to tap it in. just tap it in, so it can go home, tap it in
Old Dec 17, 2004 | 08:59 AM
METALBEAST's Avatar
A rubber mallet may not have enough omph. At least it didn't for me (may be I'm a pus ). I used a block of wood and a hammer on my Vette. Just lube the end of he crank and inside the balancer hub. Take your time and tap it in.
Good luck.
Old Dec 19, 2004 | 02:12 AM
97LT1's Avatar
I used a longer bolt like mentioned before. You just tighten to press on. It is cake walk with the longer bolt.
Old Dec 19, 2004 | 03:06 AM
TwoFast4Lv's Avatar
Air Hammer and chunk of aluminum is what I used last time. I made sure I got it started straight and drove it on slowly. I tried heating it but did not work.
Old Dec 19, 2004 | 04:56 PM
dhdenney's Avatar
I just used the crank bolt to put mine on. I didn't see any other way to do it. Of course I have the 1 piece Fluidampr so I was afraid to hit it. I have had mine in and out several times and always used the crank bolt to reinstall it. I just made sure I used lots of grease on the inside.
Old Dec 21, 2004 | 05:09 PM
zcarguy's Avatar
Thanks for the replys.
This is a stock balancer.
I went to Lowes hardware and found longer grade 8 bolts of the correct size. I'm going to try them tonight so wish me luck, I hate it when these things come up. I guess we need to make sure to ask whether these installer tools will specifically work with an LT1 before buying them.
BTW: I have a question about these FluidDamper units. My LT1 is from a Caprice 9C1 and I'm installing it into a Datsun 240Z, will the FluidDamper work with the stock accessory mounts? I read somewhere that the hub used on the iron head LT1s is longer than the Corvette or F-Body models. I'm creating a mounting plate for idler pulleys that will replace both the AC compressor and PS pump and don't want to go to all the work and then find out later that it won't work when I get a new damper.
ZcarGuy
Old Dec 22, 2004 | 04:18 PM
dhdenney's Avatar
ZcarGuy
That maybe true. I think there's a Fluidampr for the F body, the Y body, and for the Caprice/Roadmaster/Impala. Better call Fluidampr.
www.fluidampr.com
