Balanced LT1
Old Dec 29, 2004 | 01:35 PM
Rare96WS6's Avatar
Default Balanced LT1
I am thinking about purchasing an LT1 that is already
balanced. It has the factory damper, rotating assebly
is balanced, but it has no flex plate. Will a stock
one work, or will I have to get a neutrally balanced
one since the internals of the motor are balanced?
Old Dec 29, 2004 | 01:43 PM
Rare96WS6's Avatar
I forgot to mention that the rotating assebly was balanced without the flex plate
and damper.
Old Dec 29, 2004 | 02:10 PM
Mikey 97Z M6's Avatar
There are actually several methods to balance a rotating assembly.
1. Involves balancing the whole rotating assembly, balancer and flywheel/flexplate as one rotating unit. This way usually uses the stock type flywheel, which in the case of the LT1, has an offset weight to it.
2. Involves a neutral balanced rotating assembly, which requires a neutrally balanced flywheel/flexplate.
3. There is also a front/back balance like the stock LT1 uses. This is more of a "within a certain spec" type of balance. It uses an offset weight on the flywheel to balance it out within a spec.
Typically, a 'kit' that is purchased is 'usually' neutrally balanced and requires your flywheel to be neutrally balanced also. I would contact the people who put the kit together just to positive though. The wrong balanced flywheel can vibrate an engine to bearing failure.
Mike
Old Dec 29, 2004 | 10:33 PM
Rare96WS6's Avatar
So if the rotating assembly was balanced without the damper and flex plate, which are both stock, does the flex plate need to be neutrally balanced? I know the damper is already, but the flexplate has a little weight on it. Would this need to be taken off?
Old Dec 30, 2004 | 02:08 PM
Read #2 in my previous post.
Mike
Old Jan 2, 2005 | 09:19 PM
Rare96WS6's Avatar
Thanks.
Mike
