Turbo cam for LT1
Old Jan 3, 2005 | 11:36 AM
trtturbo's Avatar
Default Turbo cam for LT1
What is a good source for turbo cams for LT1's. What are some specs on a good turbo cam for the LT1. I am familiar with what an LS1 should be, but not the LT1. What shops or sponsors sell turbo cams for LT1's. Any help would be appreciated.
Old Jan 3, 2005 | 12:56 PM
dhdenney's Avatar
Numbers for LT1 turbo cams I would think would be similar to LS1s. Try Combination Motorsports http://www.cmotorsports.com/engine/l...ft-design.html or call Comp directly and they can help.
Old Jan 3, 2005 | 01:13 PM
RealQuick's Avatar
www.cammotion.com
Submit a cam request and they will spec one based on your setup. They will give you the specs, whether you buy it or not.
Old Jan 4, 2005 | 09:58 PM
Rpm2800's Avatar
Ls1's have heads that flow alot better than lt1 heads. They also have a real nice exhaust port, so these things come into play with cams . Especially turbo cams.
Old Jan 4, 2005 | 11:43 PM
SS Mark's Avatar
Do NOT call comp, the people that answer the phones are not the most knowlegable and you will get a different answer every time. cmotorsports.com has alot of cam selections, I would go there.
-Mark
