Heads and Cam, Need Help!
TSAEB...the reason people are "having trouble passing 7k" is that the stock PCM won't adjust fuel tables past that point so you won't have additional fuel enrichment for the extra needs.
)has to raise the rpm limiter even a little, it depends on the cam for how much. I wasn't sure if i needed to thats y i asked. Jeff told me i would be shifting at about 6800 rpms. To me, that just means i have an extra 1k rpms to spray
.Jeff also told me that to run that high of a rpm, i need good valve springs. SO, what do u guys reccomend for my setup? Like i said i will be shifting at 6800rpms.
THanks again, David.
