Bye Bye 6-spd
4l60
when you can easily Install a TH400 for half the price Yet its much stronger. I once converted to 4l60 from 6 speed, (thats seems backwards
), but I did. Biggest mistake. I ran a 4l60 w/ a dummy 4400 stall and it lasted 2 weeks. Then I rebuilt a th350, put it in the car and lowered the stall to 3500. It lasted a month. Apparantly I cant rebuild TH350's. I had the 4l60 built by a PROFESSIONAL
. Now Im back to the T56 and running strong. I sent the gears off and had them PRO-SHIFTED. Its' Awesome!!!!!!
4l60
Heck mine had over 50,000 miles on it when I Finally decided to open it up!
By then it had seen three motors, 14Psi of boost and Juice to boot!
I guess I am special
In the end ANY thing can be broken! I got started do transmissions because I was ripping input shafts out of TH400s! Once a month I was replacing input drums and 2nd gear 40 element HD sprags.
For beast drivers yes i would say the T56 is the way to go. they under stand the noise when they screw up...and they do screw up. I make more money fixing broken T56 parts then I do broken 4L60E parts
I just happen to need one.
