lt1 -ls1 coil per cylinder conversion
Old Jan 19, 2005 | 10:28 PM
1qwklt1's Avatar
Default lt1 -ls1 coil per cylinder conversion
I am runing a 396 with afr 220s solid roller with stock pcm with ed wright tuning am having a problem with car braking up in higher rpms for a split second looking for any buddy with any info on benifits or personal experience with this conversion.Am looking for a kit to buy for this conversion any info thanks.
Old Jan 19, 2005 | 10:37 PM
horist's Avatar
Copied from PCM section... most of the PCM Section Tech is LSx based... so hopefully between these two sections we can help this guy
Old Jan 20, 2005 | 01:57 AM
GhostZ's Avatar
I chose the Delteq over the LTCC.
The Delteq uses 4 coils from the Northstar...not one coil per cylinder but waste spark setups work just as well IMO. I had severe problems with opti's before going to Delteq and I can't say enough good things about this setup. Smooth through the RPM's, kindergarten level setup, very clean and tucked away (radiator mount), whenever the Stage II comes out, it will eliminate the opti all together. As of now it only uses the optical section of the opti so you don't have to have a functioning cap/rotor. AFAIK with the LTCC you have to have a completely functioning opti and there have been problems with wire choice and interference with that setup. A buddy of mine went with LTCC and sent it back a couple of weeks later.
On the other hand there are several people very satisfied with the LTCC...as there are with Delteq. Personally I prefer Delteq and am glad I went with it.
www.elitesparkplugs.com
www.delteq.com
Old Jan 20, 2005 | 02:51 AM
Rob 94Hawk 319's Avatar
The LTCC only uses the optical section of the opticrap also.
Old Jan 20, 2005 | 02:25 PM
1qwklt1's Avatar
Thanks for the info guys any info on prices for these setups and what kind of rpms are u able to pull witht this setup and are there pcm modifications needed thanks guys great help
Old Jan 20, 2005 | 02:55 PM
BRENTT94Z's Avatar
Have you guys done your homework on the Dynaspark??
Thats another option.
I just bought one, It wont be delivered until Monday 1/24/05.
Hope theirs not any bad write ups on this Item other than the price. I was originally waiting for the Delteq Gen2 that completely deleted the opti. Cant wait anymore. You have the same problem I had at high rpms. Its more than likely a High res failure or just weak spark!
Old Jan 20, 2005 | 04:40 PM
1qwklt1's Avatar
Do u have any info on this dynaspark? THANKS
Old Jan 21, 2005 | 08:21 AM
BRENTT94Z's Avatar
http://www.dynotech-eng.com/products.htm
Old Jan 21, 2005 | 12:32 PM
hyperzone's Avatar
Post
Here's the links :
Dyna Spark
Delteq
LTCC
Old Jan 21, 2005 | 10:52 PM
1qwklt1's Avatar
Appreciate it guys
