LE2 Sound Clips
Old Jan 20, 2005 | 05:50 PM
balplaya10's Avatar
Default LE2 Sound Clips
I am going to be getting the LE2 package soon and i was wondering if someone could put a sound clip or video of their car with the same package so i could get an idea of what it is going to sound like.
Thanks!!
Old Jan 20, 2005 | 07:43 PM
Shawn MacAnanny's Avatar
I would like to hear this too. Bump for you!
Old Jan 20, 2005 | 10:23 PM
Z95m6's Avatar
It will probably sound much like most sound clips of cars with larger cams. Sound clips very so much because of exhaust and mic placement it all sounds diff anyways.
Old Jan 20, 2005 | 10:35 PM
Well i mainly wanted to hear it cuz of the LSA. They are supposed to be around like .600 lift with a 109 LSA or something. I dont know that for sure, just a rumor. The CC306 and GM 847 are like .570 lift, around the same duration, but a 112LSA. The tighter LSA gives it more of a lope, that's why i was curious.
Old Jan 20, 2005 | 10:36 PM
simple's Avatar
check sig, wait for the download (slow server)
not technically an LE2 cam but it is a cam from Lethal EFI Performance, where Lloyd gets his cams and it is the same duration as the LE2
same cam different name since i didnt get it from Lloyd is what i'm saying lol
i've got one other one too if you want me too find it
Old Jan 20, 2005 | 11:24 PM
That sonds so sweet. Low sound quality, but very awsome nonetheless.
Do you have any where you rev it up?
What kind of exhaust do you have?
Old Jan 20, 2005 | 11:41 PM
simple's Avatar
here ya go
http://www.unrealhp.com/midwestcruise/exhaustcomp.wmv
(5.5mb, same slow server, be patient it will load)
Hooker long tubes, 3" IRS off road y-pipe thru a loudmouth
Old Jan 20, 2005 | 11:44 PM
Plenty fast for my dial up Thanks i'll replay in about 2 hours when it's done downloading.
Old Jan 21, 2005 | 04:28 PM
That sounded so awsome man. I am definately getting the LE2 just so my car will sound like that lol. 116Db from 15ft or so is pretty insane man. Awsome car. What did it dyno or run?
Old Jan 22, 2005 | 09:34 AM
simple's Avatar
i've had nothing but opti spark problems since i've done the install
it did dyno 311rwhp at 3000rpm, opti was braking up after that
1.87 60ft 12.50 @ 112.75mph granny shifting at 6000rpm with the bad opti in it (bone stock suspension)
new opti is going in within the next month
i have advanced induction heads but Lloyds stuff should be very similar in performance
it should be capable of low 11's at about ~120 (but i hate bench racing)
the tune is done by the fella that did my cam
Old Jan 22, 2005 | 11:04 AM
Do you have a dyno graph, or know how much it made around 1500 rpms? 311rwhp at 3,000 rpm is really good. I was just curious because i will be running the stock 1500 rpm stall and wanted to see how that compared to a stock cam.
That 12.50 is awsome too for a bad opti. What mods do you have done?
Old Jan 23, 2005 | 09:53 AM
simple's Avatar
the dyno pull started at about 2800rpm, i dont have it online anywhere too show you.
mods are just your basic stuff, electric water pump, pro mag 1.6 rockers, R series lifters, Cloyes true roller, SPEC 2, 12bolt 4.10's, etc. etc.
you are definately gonna want a bigger stall, especially with that cam
Old Jan 23, 2005 | 10:17 AM
DopdBrd's Avatar
Way Off Topic But Would His Head And Cam Combos Work Good With Nitrous??? Im In The Process Of Building A 383 And Im Going To Run Nitrous, Now Im Just Looking For A Good Head And Cam Combo. Thanks
Old Jan 23, 2005 | 01:27 PM
Brett95z's Avatar
How much are you planning on spraying? The tight lobe sep isnt going to be very nitrous friendly. But 100 shot or so will still be cool
Old Jan 23, 2005 | 02:21 PM
DopdBrd's Avatar
I Plan On At Least A 150 If Not 200. Its Going To Have All Forged Low Compression Pistons Because In A Year Or Two After I Get My Money Saved Up I Might Get A Procharger.
Would U Guys Recommend The Le Package Or I Was Also Thinking About Advanced Induction. Any Sugesstions???
Old Jan 23, 2005 | 04:07 PM
He could custom grind a cam for your specifications. He was gonna grind one that i could pass emmissions with, just talk to him, and he'll let you know what he can do.
