A.I.R Diverter Tubes / EGR removal?
I have read materials on this subject, but does anybody knows or has actually done it? I have a 1993 Trans-Am with the A.I.R. diverter tubes and EGR on the back of the Intake, I know the 93 T/A is slightly different than the mid 94-97 model T/A's. What I need to know is what does it take to make it work right once it has been removed. What are some of the problems if any will I encounter? Will I need the block off plates? Will I need to retune the ECM, because the 93 models came with ECM not PCM's, Will I need to take off the smog pump or should I take it off? Any, help would be greatly appreciated. Thanks in advance.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
