Rant about my LT1
Old Jan 24, 2005 | 12:52 PM
OneMeanZ's Avatar
Default Rant about my LT1
My car has 108,000 miles on it. I know that when cars have miles that stuff start to go bad. Well I'm going to start with some things that just come off the top of my head.
I think my springs and shocks are wore out, because my driver side sits lower than my passenger side. The car rides rough, I think a new set of springs and shocks would fix that problem...
Next, I got a SPEC Stage 2 put in the car in August. Clutch doesn't feel all that good, chatters real bad and ****. Not sure if it's the flywheel or clutch.
Next again, I have a kick *** exhaust leak. It's annoying as hell and not sure if it's hurting me performance wise or not.
Then, I logged my car today and noticed that when I was at 76% throttle and 4650rpms I was seeing 11 degrees of retard.
It sucks and if anyone has any comments let me know. I just felt like ranting. Thanks for reading...
Old Jan 24, 2005 | 01:03 PM
RossB's Avatar
i know that a SPEC 3 clutch chatters real bad, but i dunno about a SPEC 2, i would imagine a little chatter tho
Old Jan 24, 2005 | 01:56 PM
Crazyz28's Avatar
If you don't have it already, get a Lt4 knock module for the retard. Exhaust leaks are the most annoying things, except for a squeak coming from somewhere in the rear of the car (at times I think I'm just imagining it cause I can't tell where it's coming from).
Old Jan 24, 2005 | 02:33 PM
hotrod18_69's Avatar
Can't help you much on the Spec clutch, but new springs and shocks will improve your ride like night and day. As for you kick *** exhaust leak, get it fix as soon as possible. You are losing performance from it and it could also be triggering that knock retard you have.
Brad
Old Jan 24, 2005 | 03:44 PM
METALBEAST's Avatar
I was talking to my buddy Mike (Mike02LS1ss) the other day and he was talking about how crappy his SPEC Stage II clutch was (chattering and slipping).
Old Jan 24, 2005 | 09:10 PM
OneMeanZ's Avatar
Thanks everyone for the respones, once my buddy gets his lift finished I'm going to fix that exhaust leak and when I get the money Eibachs and QA1s are going on the car
