396 cubic inch lt1 with t76
how fast do you think this combo should be able to go ? it is Motor: 396 with 9.4:1 cr, 4 bolt splayed caps, canfield heads that have been fully ported, custom turbo cam by Comp Cams intake an exhaust is 230-235@50 , 544-555 on a 114 , r series lifters, Ferrea valves, Callies crank, JE pistons, Oliver Rods, 58 mm tb, #65 injectors, F.A.S.T. tuned by Harry Hruska at Precision, Walbro 340 fuel pump, electric water pump, T76 turbo, custom 1 3/4 headers, intercooler, 3 1/2 dp to 3"SLP exhaust . 6 speed with mccloud twin disc and 3.50 gears in 9 in. it is in a stock weight 94 camaro .
