does the comp cams distributor gear fit
Old Feb 15, 2005 | 02:35 AM
camarolt195's Avatar
Default does the comp cams distributor gear fit
i have a 95 camaro z i was wondering if the comp cams bronz distributor fit and work like my old oil pump drivetrain will it fit it is a .491'shaft part #dg88 in yearone.com
Old Feb 15, 2005 | 04:35 PM
crow2's Avatar
WHAT CAMSHAFT DO YOU HAVE???
Old Feb 16, 2005 | 12:20 AM
i have the original one that came with my LT1
Old Feb 16, 2005 | 11:36 AM
crow2's Avatar
You cannot use a bronze gear with a stock camshaft! The stock cam is Not a billet core,You will need to use the GM melonized dist.gear~#10456413 $24.95.The bronze gear is to soft and the cam would eat the gear up!Hope that helps you out! thanks!
