crankshaft bearing problem
When i push the clutch all the way to the floor you can hear this grinding sort of shattering ticking noise and the guy at GM told me that i am hearing something going wrong with the crankshaft? Can someone help explain this to me better?
I am so confused....What are the causes of a worn out crankshaft bearing and why would i need a whole new crankshaft? He said if i keep driving my car its gonna break and destroy the engine. Do i need a second opinion? lol What are my options? I didnt think stuff like this went wrong on a engine that only has 102,000 miles? Sorry this is kind of long.
BEN
A spun bearing usually sounds like a LOUD knocking noise, constant regardless of clutch engagement -- actually sounds wooden like someone knocking on a door. NOT a good noise.
If you only hear a noise when depressing the clutch pedal, that would lead me to believe it's associated with the transmission/clutch -- not the motor. Pressing the clutch in disengages the clutch by pulling on the throw-out bearing. Perhaps you've got something torn up along those lines (clutch disc/pressure plate/throwout bearing/clutch fork). Could you describe the noise a little more? Stock clutch?
IOW, yes, I'd get a second opinion...
BEN
If, perhaps, your pilot bearing was in really bad shape and/or fell apart, I could see how the snout of the trans could maybe start to warble the crank a little.... maybe. It would make screeching and/or grinding noises, yes.
No matter what, I'd go over there and take a look at this "bad part" before authorizing ANY work. Their response sounds pretty vague.
They told me that just replacing the bearing wont help because the crankshaft is old and is probably worn too...
They said the car is drivable for a while but probably not all that long.
Why cant i just replace the bearing? How does the crankshaft get ruined in the process? Should i check the oil to see if there is flakes in it? If the crankshaft is moving back and forth how long can i expect the car to go, can anything else go wrong? Is it time for a 383 rebuild?
Thanks for all your help. BEN
What happens is that the thrust bearing wears into the crank. Once that happens you really just need a new crank and a rebuild.
Sorry man, but you can always get a second opinion....
Mike
Mike
If your crank has more than .015 of end play...time for a rebuild...if that's the case. My opinion of most GM techs is not of high character. They can take that piece of paper and shove it. Some others though, are wizards and geniuses. take it to a good tranny shop to have them diagnose it. they know more than GM techs when it comes to clutches. A GOOD tranny shop.
im my experience i have found that some of the oldest and sometimes crummiest places will know the most and do the best work with transmissions. experience counts for a lot. sure a chain may have been around a long time, but the employees havent been i bet.
Either way, if you have excessive crank endplay, you're looking at a rebuild.
Mike
