Recent Dyno Results
1994 Z28 M6 Coupe
Lloyd Elliott Heads, 2.02/1.60 valves, Combo 612 springs
1.6 Pro Mag RR's
Comp XE 227/233, 560/569 camshaft
Jet Hot LT's, True Duals (x-pipe, race bullets)
Moroso CAI
Moser 12 Bolt, 4.56 gears
Nitrous Works 175hp plate system
I am still running the stock unported intake, stock water pump, stock pullies with AC and did not drop the belt for the dyno pulls.
Prior Dyno before True Duals, had a Hooker Y-pipe and Hooker Catback 356hp/347tq with a 13.1 AF ratio
Dyno from this weekend, only change true duals. 347hp/328tq with a 11.9 AF ratio....just a little rich
Dyno from this weekend with 175 shot of nitrous. 497hp/510tq with a 12.9 AF ratio.
The rich NA condition turned out to be good for the nitrous pull. I plan to run nitrous at the track anyway so I am not too concerned with the NA numbers being a little low.
Those look like a great set of heads. People are making 350+ RWHP with ported heads and just a hotcam. I would just expect closer to 400 RWHP with that came. Not knocking anything. I just think you could get alot more with the right tuning
Edit: Oh yeah, did I mention my car is an automatic?
You should be able to get very close to perfect with a mail-order tune. I recommend PCMforless, the last 2 I've gotten from them have been great.
