MSD Opti Spark
Old Mar 1, 2005 | 07:11 PM
01WS6/tamu's Avatar
the optical sensor in the opti is going bad. You may as well just go ahead and buy the whole unit.
Old Mar 15, 2005 | 11:57 AM
mySStery_machine's Avatar
Vented or non-vented what is the difference and which is better?
Old Mar 15, 2005 | 05:01 PM
chug's Avatar
I seem to be having the same skip/miss/cutout at about 5000rpm. Sometimes i do get enough to get it to 5800rpm so it will shift but more times then none i have to lift to get it to shift. I'm not getting any codes, could the opti be some of the problem??
Old Mar 15, 2005 | 10:13 PM
97blkz's Avatar
Non vented I think was 93-95 lt1's ,vented 96-97??
Yeah I have burnt up 3 optis in my 396 stroker in 3 months , so the boys at Rev xtreme have made som adjustments to it and we will see. Either way I plan to convert to coils by year end!
Old Mar 16, 2005 | 01:18 PM
Can you upgrade the vented into a 95 LT1? My friends Caddy with the LT1 seems to be having a problem and I have a feeling it's the opti. I had the damn near exact problem with my 94 Z. Just wanted to know if they are interchangeable.
Old Mar 16, 2005 | 02:05 PM
madhatter's Avatar
The caddy will already have the vented. To convert a non to a vented, you need a new cam, timing cover, distributor, harness, and vacuum line.
Old Mar 16, 2005 | 06:42 PM
Y2kHawk05's Avatar
So, has anyone even received the MSD Cap & Rotor yet? I freaking doubt it since MSD is not showing a release date until March 31. I ordered one through HPE here in Houston after I called MSD to find out it's the whole unit. Internal sensors and all. I have been waiting & waiting only to have MSD put it off again. If anyone has received their MSD unit, please reply to this...
Thanks,
Old Mar 17, 2005 | 06:37 AM
So all the Caddy owners got the vented then automatically? I just want to make perfectly certain before having him purchase the wrong part. The vehicle is a 95.
Old Mar 17, 2005 | 09:00 PM
GWTFI's Avatar
Yes, all 1994 - 1996 B/D bodies (Caprice, Roadmaster, Impala, Fleetwoods) got the vented Opti.
I have a couple of spare optical pickups I keep aside just incase one goes bad I can replace just that part.
Old Mar 18, 2005 | 09:59 AM
Jason Blue Boost's Avatar
I have Dynotech Engineering Opti and the car feels stronger that it has in a while. All the faults of the GM one are corrected in this one.
Old Mar 18, 2005 | 11:41 AM
Jason, how much was that one and where did you get it?
Old Mar 21, 2005 | 07:10 PM
  #32
01WS6/tamu's Avatar
I ordered my kit from summit and I have had it on the car for about three weeks now I believe. It is a good kit and I have had no problems.
