Intake Manifold Oil Leak Fix
Old Feb 22, 2005 | 03:29 PM
LoudmouthLT1's Avatar
Default Intake Manifold Oil Leak Fix
I'd just like to say how easy this fix is. In less then an hour I was down to just the intake, so in 12 bolts the thing will be off. And this is working in 30 degree weather with a flash light while the car is on jackstands so I need to be standing on something to reach in the back. So no one should fear doing this, the only special tool needed is a fuel line disconnect tool, other then that its just sockets.
Old Feb 22, 2005 | 03:45 PM
brandboZ28's Avatar
The important thing is that you sit the intake straight back down so it seals properly. Also, dont forget the 2 10mm bolts on the back of the intake that hold on the emission tube if you dont have it blocked off already.
Old Feb 22, 2005 | 03:51 PM
Already blocked off
Old Feb 22, 2005 | 07:49 PM
curlyws6's Avatar
The two 10mm bolts, are they the ones that hold the EGR and AIR tube on the rear of the intake? I am getting ready to block off the AIR and EGR on an intake which I bought (which is bare) and I need to know the bolt size for these two items. There are usually studs in both with nuts but they were removed from this intake.
Old Feb 23, 2005 | 09:05 AM
brandboZ28's Avatar
Yea, those are the ones but I dont know what thread count they are or anything like that.
Old Feb 23, 2005 | 11:34 AM
curlyws6's Avatar
Cool..... I guess I'll have to drag the intake into Lowes to find all the bolts that I need, should get some funny looks doing that!
