Quote on instaling headers
Old Feb 22, 2005 | 05:29 PM
ALBurgZ28's Avatar
Default Quote on instaling headers
I ordered the Pacesetter LTs and went down to the shop I get all my work done at. He quoted $500 to get them installed. Does this sound right or should I get a second opinion?
Old Feb 22, 2005 | 05:41 PM
Lt1FBoDy209's Avatar
Although that is high, there is a lot of work that goes into installing headers. I got quoted around 300 tho so you might want to see if you can get it done somewhere else for less.
Old Feb 22, 2005 | 05:49 PM
ALBurgZ28's Avatar
Allright thankx. Also I need some help. If I get this: http://truckperformance.com/products/?productID=457006 (with the headers) Would I be able to maybe run dual mufflers(flowmaster super40), one on both sides of the pipe or would it be better to run the pipe into one muffler? Or would I be better off with a single Y-pipe after the headers.
METALBEAST's Avatar
If you have a garage, I would try doing it yourself. I installed headers on my Vette in my driveway. Its a bitch but you'll never learn til you try. That gives you $500 for more mods
Old Feb 22, 2005 | 05:51 PM
ALBurgZ28's Avatar
What all do you have to remove? To install them?
Old Feb 22, 2005 | 05:53 PM
FIREHAWK #07's Avatar
do it yourself... get some buddies to help ya.... buy'em some beer, pizza, and some more beer.... should cost you less than 75 dollars, lots of busted knuckles, and priceless memories of you and your buds installing the LT's..
Old Feb 22, 2005 | 05:54 PM
if you do go with one muffler and u want to go with flowmaster DONT get a 40 series one. 80 series mufflers are so much better.
Old Feb 22, 2005 | 05:55 PM
LoudmouthLT1's Avatar
Alternator, steering linkage, sometimes an a/c line needs to be disconnected, spark plugs and wires need to come out, starter has to be moved and the old y pipe has to come off. With long tubes you may need to unbolt an engine mount and jack the engine up a little to get them in there.
Old Feb 22, 2005 | 07:34 PM
curlyws6's Avatar
^^^ Sounds right on the spot...if you make sure you can get the car a good distance off the ground, it's not a bad job at all. I have helped with two installs on f-bodies, mine and a LS1 formula. We did the formula on jack stands and mine on a drive-on platform. Do it yourself if you can get some help and are even somewhat mechanically inclined.
Old Feb 22, 2005 | 10:46 PM
musclehead's Avatar
I'm with the majority on this one, do it yourself.
Old Feb 23, 2005 | 02:55 AM
12secondDream's Avatar
hmmmm, headers and beer....sounds like fun!!!
Old Feb 23, 2005 | 11:50 AM
1bottled93toenvy's Avatar
ummmmm.....i second that one pizza and beer do sound damn good...do it urself..it will be hard but with the right help u will learn a lot
