Is this right...
Old Feb 22, 2005 | 04:23 PM
strobelite's Avatar
Default Is this right...
This is with teh car idling in park. Not sure what all the codes mean.
I got a MAF failure CODE 48 also
Old Feb 22, 2005 | 04:50 PM
somecarsome's Avatar
what elevation are u at plus look at your knock count
Old Feb 22, 2005 | 06:23 PM
Fastbird93's Avatar
Looks like you have a pretty nasty fuel trim split too. What are your O2 Mv doing while idling I.E. are they cycling from low to high or other???
Fix your MAF too. That could very easily be causing your fuel trim split.
Old Feb 22, 2005 | 06:33 PM
strobelite's Avatar
Fix the MAF, I.E Get a new one?? Is there a way to test it? The o2 mv is moving from low to high.
Old Feb 22, 2005 | 07:12 PM
Fastbird93's Avatar
See if someone's got the diagnostic chart to check the pinout voltage and see where the problem lies. Odds are it's a true MAF problem, but it could be a connection problem @ the MAF or computer.
