What do you need for 350 rwhp?
Old Feb 22, 2005 | 08:55 PM
AJ Bertelson's Avatar
Default What do you need for 350 rwhp?
Would be a dual exhaust setup with no cats.
doing a quick and dirty search it looks likes, cam, roller rockers and a slight port job.
Old Feb 22, 2005 | 09:05 PM
METALBEAST's Avatar
Depends on what type of tranny and tune. Ported heads, LT4 Hot Cam, 1.6/1 RRs all boltons routinely makes 350 RWHP. CC306 Even more.
Old Feb 22, 2005 | 09:17 PM
LoudmouthLT1's Avatar
You can probly just do a big cam and make that power if you have full bolt ons and 1.6 rockers.
Old Feb 22, 2005 | 09:21 PM
BizZzatch350's Avatar
Moderator
This an auto or six speed, also does it have a 10 bolt?
Old Feb 22, 2005 | 10:10 PM
RymerC's Avatar
Porting isn't necessary. However, to do it without porting is going to require a pretty aggressive cam (comp306) and alot of RPMs (6200ish). It will be alot more fun to drive if you chose a more mild cam, and sacrifice those 20 peak ponies for 20 foot-lbs.
Old Feb 22, 2005 | 10:46 PM
Moderator
With the stock heads you can runa lto smaller than a 306, people have made that power with hot cams in six speed cars, its just when you put heads on it the bigger cams will shine but on stock heads, no real point.
Old Feb 23, 2005 | 10:10 AM
Trans would be six speed, looking at a dana 36 or using the stock 10 bolt.
Complete car would only weigh about 2100lbs though so rear end isn't a issue.
I am sort of debating about wether to spend the extra cash and get a LS1 or go a little cheap and stay with the Lt1.
Old Feb 23, 2005 | 10:15 AM
SAPPER's Avatar
LS1!!!!! My 02 Z ran 13.2@106 stock. Takes too much for Lt1's to get that far but the LT1 can make gobs of tq and are more economical to work on...if you do away with the optishit.
Old Feb 23, 2005 | 11:40 AM
93ZM6's Avatar
How do you do that? Please let me know!
Old Feb 23, 2005 | 11:59 AM
SAPPER's Avatar
2100????? holy schniekies. I misread that, I thought it was 3100.
OK, I wanna know too
Old Feb 23, 2005 | 12:25 PM
93ZM6's Avatar
Hey sapper where can i read more about that engine, is there a website? Does it fit into camaros lol
Old Feb 23, 2005 | 12:45 PM
Poik's Avatar
Maybe he is picking this engine for a 240Z or something? Those are awesome and weigh only 2300 or so stock! If you have the option now, go LS1. Lots more power to begin with, you will probably have to spend around $750-$1000 to get the LT1 up to LS1 specs to begin with. The LT1 is more torquey, but with a car that only weighs 2100 pounds you shouldn't have to worry about that. Go LS1, they wake up a lot quicker to mods anyways. For 350RWHP on an LS1 all you need is all the boltons.
Old Feb 23, 2005 | 03:10 PM
Check out the latest issue of kit car.
Its not the ultima, uses camaro running gear and can be built for under 20 grand.
Old Feb 24, 2005 | 01:15 PM
Formula94's Avatar
I am cam and full boltons only, stock heads/bottom end, and N/A. I put the numbers in my sig up. That was before I got a new opti and electric water pump though, so I might be making a little more.
Old Feb 24, 2005 | 01:58 PM
Vendetta's Avatar
LT1s can easily make 350rwhp. And they don't necessarily make more torque than LS1s, they just produce the torque lower in the band.
Old Feb 24, 2005 | 05:00 PM
~JOSHUA's Avatar
Lightbulb
The easiest way to make 350 RWHP is to buy a Paxton supercharger for $2,700. Similar money, easier install than heads and cam.
Old Feb 24, 2005 | 06:14 PM
Vendetta's Avatar
Way overkill for 350rwhp. You can do it with just a cam. Plus, a h/c car is a hell of a lot more reliable and easier to tune than a blower car.
