Timing Chain Question.
Old Feb 28, 2005 | 04:40 PM
z28racerlt1's Avatar
Default Timing Chain Question.
I see alot of 3 key way slots on the crank sprocket. Is there any companies that make a 9 key way slot timing chain set for the LT1.
Thanks
Ken
Old Feb 28, 2005 | 06:03 PM
Snow Dog's Avatar
try comp cams for a hex a just timing set i dont know for sure if they have one for the LT motors. this has an allen headed cam that allows you to turn it to any degree or part degree up to a certain amount. this will allow you to degree the cam correctly. the two other key ways on the timing set advance or retard the cam an already set amount. typically 4* plus or minus.
