how does the gm847 do on boost
Old Mar 6, 2005 | 01:16 AM
Boostaholic's Avatar
Default how does the gm847 do on boost
I need to know how the gm 847 reacts under boost, and also if anyone would know what kind of power it would make with 9 psi. I know it's not the ideal cam for boost, but how is it for low boost pressure, like 4 - 6 psi?
Old Mar 6, 2005 | 07:46 AM
TwoFast4Lv's Avatar
It is a little big and has more over lap the you might want IMHO
now if you set it on the right ICL and LSA you would have some thing alot more usefull
Old Mar 7, 2005 | 10:23 PM
tjwong's Avatar
Have Crane grind it on a 114 LSA and it will work much better. I spoke with them about that cam for use with a Vortec blower pushing 12 to 14 PSI. They say it will work fine with the appropriate heads and exhaust. But 14 PSI is the absolute maximum boost with that cam.
