temperature
Old Mar 11, 2005 | 05:43 PM
studlybilly's Avatar
Default temperature
Finally got most if not all the bugs worked out on the slomaro. I was curious about a few things. On the water temp gauge, there's 5 levels (2 numbered of course being 160 coldest and 260 hottest). Being I have the stock thermostat, where exactly should it be? I noticed it liked to rest between the 2nd and 3rd line (3rd line being dead center between the 2), but then it'll rest right on the center line. Is this normal? I'm guessing being in the dead center of 160 and 260 its 210? I was looking at 170 or 160 degree t-stats, but are the fans set to engage at x degree or just whenever the t-stat opens? Just trying to make sure I'm not overheating when I think its normal.
Old Mar 11, 2005 | 05:56 PM
LoudmouthLT1's Avatar
Yes 210 is normal operating temp. A 160 thermostat will open sooner but the fans still won't come on until 210ish. They basically won't come on unless you have a/c or defrost on or are sitting for a long time.
Old Mar 11, 2005 | 06:05 PM
Alright, but if I put a 160-170'sh t-stat will it keep the check engine light on? I can put a switch to the fans on either the ignition or a dash mounted switch. and last question, will MPG be effected being the vehicle will not be at its normal operating temp?
Old Mar 11, 2005 | 07:47 PM
No the SES light won't come on at all and gas mileage should be the same.
