Head Gasket Options
Old Mar 13, 2005 | 10:54 AM
Boother's Avatar
Default Head Gasket Options
I am going to be swapping out the heads on my car for a set of ported stock castings, and I would like to know what head gasket options I have. I wouldn't mind increasing the compresion ratio by using a thin gasket.
Thanks,
Mike
Old Mar 13, 2005 | 06:49 PM
GhostZ's Avatar
Impala or Mr. Gasket head gaskets...that'll give you an extra .020 as the Impy's are .029", Felpro .039 and stock .049 when compressed.
Old Mar 13, 2005 | 08:24 PM
Boother's Avatar
What will the compression be with those gaskets on the stock motor?
Old Mar 13, 2005 | 09:42 PM
GhostZ's Avatar
You'll raise the CR by MAYBE a half a point...the best thing it does, which really doesn't apply much here, is get you to a better quench height.
You aren't going to see much of a gain going with a thinner gasket. You could have the heads milled while they're off but there's nothing like changing the CR the old fashioned way...
