What fuel/ignition to go with?
What is the capability of the LT1 fuel system (stock)? I know that since I want to run nitrous I will need a new fuel pump, whether it's a intank or inline I don't know. Will an inline pump work fine or should I just go with an intank? Do I need to run a different regulator, what is recommended? And finally, what are stock injectors capable on doing? Mine you, with nitrous I will hopefully be making ~550RWHP and I don't feel like replacing pistions right away
Now for the ignition system. What should I run for an ignition system to get full potential out of this setup (ignition box, coil, wires, plugs)? I really have no idea what would be the best way to go, so I need some helpful suggestions on this part. I don't plan on spinning this thing past 6500RPM and I'm 99% sure the stock opti is capable to do that. But I was thinking just for extra insurance just to go with a new Dynaspark opti.
Am I headed in the right direction?
Ok I'll try. The motor will be running out of fuel, I believe, as it sits right now with the Lloyd package without nitrous. So going up to a 30 LBS injector would help that out and would be great for the spray. I think the best thing would just be to put the intank pump in cause depending on how many miles u have on the car already the pump may be running a little low on power anyways. Now for ignition you would benefit from all of the above. The stock opti has some problems in the higher RPM range so the Dynaspark will help that, but if it were me and I was going to spend the money anyways y not just step up to a coil over plug situation. This can be debated also (the opti's holding up in the higher RPM range) cause some have problems some dont. I personally had a problem with my first one but spun the 2nd one up to 6800 all day long on spray without a problem. Maybe someone else can help you a little more but that's all I have for now.
