355 Lt1 Build
1.6 rockes and i'm thinking of running a cam in the range of 232/242 575/595 lift with a 112lsa. I also have fully ported intake gasket matched to heads with a bbk 58mm throttle body BBK shortie header, borla exhaust,
I'm goning to update the fuel system with bigger injector and fuel pump,
get the ecm dyno tuned, and probally run a 2800-3200 stall with 373 gears
provided all this do you think i will be able to run a 175-200 shot on pump gas?
Any ideas on any other things i can do to make power.
people keep telling me to build a stroker. but what i really want is a motor that can pull some higher rpms.
