how to remove the cam and crank gear?
If you have the timing cover off and you can't seem to pull the cam out, you probably forgot to take off the cam plate that prevents the cam from moving forward. Its held in by 2 bolts and it can be easy to miss.
Yes, they are held in by Torks Head bolts. They are not supposed to just fall out though.
