rotor disintegrated AGAIN on opti!!! WTF!!!
to top it all off, Autozone won't warranty the whiole assy, just the distributor, even though i bought it as a unit! what is up with that!!!!! i have not been insulted like i was today at the autozone in the detroit area earlier today ! ******' ********. i hope the district manager will assist me in reoslving this issue. at this point want the replacement to put on a shelf as a spare and put something else in there, like the msd, the dyna spark piece looks nice but man that is very expensive!!!!!
i have enuff stuff under the hood i don't want to add coils and all that extra f'n wiring!
the dynaspark is worth a try, but that is a fair bit of coin to part with!!!!!
Perhaps you could try to find a different Autozone that would honor the warranty. The Autozone here in KC actually instructs me to rip them off. They're funny...
A Pre-95 opti will also require a pre-95 cam gear and a pre-95 opti wiring harness. You might have to order the splined opti driveshaft separately. I can get the GM part numbers if you want to go that route, but I'm not sure if that would be beneficial on such a radical setup. If you can wait for the new MSD units, they probably use a stronger rotor. Otherwise, if you want to get away from broken rotors, you're probably looking at the Dynaspark or one of the coil-conversions ($$$).
I highly doubt you'd want it, but I figured I'd at least offer: I could mail you my 70,000-mile 1994 rotor for the time being.
I've got a coil conversion, so it's just spinning in there for no reason -- I could fabricate a washer in it's place. The car is already torn apart for a blower buildup. Pay shipping and it's yours... Trending Topics
Don't think RPM is the problem.
Good luck, Ed
thanks for the offer, buti don't wnat to convert to a different cover etc...
i measured the dowel, and i can even see the wear marks on the inside of the dowel location, i am at least .080" from bottoming out, at first that is what i thought had happened. i took some quicl measurements and the dowel does in fact stick out about .040" farther than the one in the previous cam, i can grind it down for piece of mind, but i am positive that it was not bottoming out.
my dowwel currrently measures 0.473" from the surface of the cam retainer, which is .182" thick.
Ed,
i spun mine for the most part to 7k or a touch more. i actually plan on spinning it harder this year. so i want to make sure i have thus nipped in the butt. i nver realized that the screws were an issue! i will open up the unit that i get from autozone and do as you recommend! but i am still leary abotu instaling it on the car! lol!!!! is there a torque spec for the scres, lol!!! how many inch.lbs ?
i wonder if the cap and rotor from msd is a little more durable???
thanks alot folks! i do appreciate it!
the last time i looked junder your hook it was VERY VERY VERY clean....
the msd ignition has done a fine job of keeping up it is the opti that has plagued me as a late. it was great for 3 years until i last summer.schurter,
thanks! but with the coil packs comes wires, and brackets, and i can't use the 6al, or digital retard box.
ultimately it is cheaper now to replace warrantied opti, at worst for out 150 for the msd cap and rotor. i am gonna call msd to inquire about the cap and rotor. certainly ed's tip might be an opti saver right there!
Good luck, Ed
You can run a 1992-1994 cap and rotor on your 1996 rear section with slight modification. That's what I've got in my car right now -- somewhat of a hybrid. All the rotors should be identical. Just fyi -- good luck.
thanks Alex, i didn't know you could run the older cap and rotor, cool! no harm done on suggestion
i shot Pete an email over at delteq, i want to talk to him tomorrow, at the very least i will decide what the hell i am going to do
i have dyno time scheduled for next weekend, so i hope i can finish this up, we'll see. Ed,
Good luck, Ed
i really didn't want to go that route for 2 reasons, first cost, and second having to rewire my n2o setup completely! it is currently controlled via digital retard box! grrrr! now it won't be. i also need to figure out how/where to pick up signal for shift light?
so i will soon have an msd 5al box for sale, a msd digital 6 retard, and a almost NEW coil. lol!!!! the **** we go through.
thanks Ed, autozone did replace the complete assembly although it is the dist, and cap/rotor separate. i am running the dfi gen 6 d, i installed it last winter and ran with it last year, i actually did shift the car at 7200 one event without issues.
only area i will need help now is figuring out the wiring for the gen 6 and nitrous controls. i am not fond of wiring, i guess i never used to be fond of removing my trans from the car, so oh well, lol!!!
thanks again for the coments.
