Pushrod Help
Old Mar 29, 2005 | 09:04 PM
wc00ac's Avatar
Default Pushrod Help
I need a set of stock length pushrods that are hardened for my 94z. Where is the best and cheapest place to get them? What is the actual length and diameter that I need? Thanks
Old Mar 29, 2005 | 10:36 PM
Alex94TAGT's Avatar
5/16" diameter, 7.200" length.
I bought some hardened Comp Cams stock replacements from Thunder Racing. I think they were about ~$40? Don't remember...
[Edit] Check for a dot along the shank of your factory pushrods. You might have hardened from factory. (-in fact, you should. Mine were.)
Old Mar 30, 2005 | 07:31 AM
wc00ac's Avatar
Thanks I will contact them.
Old Apr 3, 2005 | 09:01 AM
wc00ac's Avatar
[/QUOTE][Edit] Check for a dot along the shank of your factory pushrods. You might have hardened from factory. (-in fact, you should. Mine were.)[/QUOTE]
Is this correct? That just doesn't seem right. There is a dot on them. But can you be cetain.
