crazy dyno = bad opti ???
My BIG QUESTION is : Does this sound like an opticrap symptom?
ALSO : Does anyone have any dyno results showing what a bad opti will look like???
I really appreaciate any help/advice I can get. The first dyno I ran back in January had shorty headers with all emissions hookups and I was running with the HTPP3 tuning. The air/fuel line was running at like 11.5 flat up to 4000rpm. Between 4000 and 4500 it rose quickly to 12. From 4500 to 6000 it has a slight hump/curve where it peaked at 12.5 for the run
The second dyno which I ran the other day was with pacesetter long tube headers hooked up to the TSP x-pipe true dual 3" inch exhaust (no cats), LT4 Knock module installed, removed secondary air, removed and capped the egr, installed breather and plugged PCV spot on TB. Also, The rear O2 sensors are not hooked up and the front two had to be extended for the long tubes. No HTPP3 tuning. The air/fuel on this run looks like the exact same line, just minus one. Like instead of starting at 11.5 flat it was 10.5 flat and so on.
The crazyness in the hp line starts at that jump in the fuel ration between 4000 and 4500. And after that change it just goes completely wacky and basically starts declining as its jumping up and down. Thats the best description I can give in words. Send me a PM with your e-mail addresses if anyone would like to see the dyno sheets. Again, I really appreciate all the info and suggestions I can get. Thanks guys!
This was caused by a spark plug wire hitting the power steering pump and arcing. But it did make for a CrAzY dyno graph
Ryan
