aggressive cam for stroker engine?
Old Apr 6, 2005 | 08:28 AM
Fahad's Avatar
Default aggressive cam for stroker engine?
Hello everybody...
I need help to find hyd cam very aggressive street/strip. for stroker engines LT1's. My friend need to change the cam cause it damaged so he plan this time to install a big and better one. the old cam was 237/244 575/595 114 (1.6)
Thanks
Old Apr 6, 2005 | 11:17 AM
dhdenney's Avatar
On a 112 lsa, that would be pretty aggressive. Just call Comp or Crane and get a suggestion. Doesn't cost anything extra for a custom ground really.
Old Apr 6, 2005 | 02:37 PM
Fahad's Avatar
You're right... but I would like to see some different cams they used. Comps told me any specs we can build it for you, so need info about that to build the right cam for my friend setup. the setup 383ci, hand ported heads stage2 , 2.02/1.6 valves, Flat piston KB, Rod length 6.000
Old Apr 6, 2005 | 08:20 PM
GhostZ's Avatar
Custom grind.
Get the flow sheet for the heads and either call Comp or I would recommend Bret Bauer (SStrokerAce on CZ28).
He knows his poop and can get you a custom grind that I can guarantee you won't be disappointed with.
There are quite a few off the shelf grinds that would do well with whatever his setup and more importantly head flow is....but you can't go wrong paying a little extra for a matched cam.
Old Apr 7, 2005 | 07:15 AM
Fahad's Avatar
Originally Posted by GhostZ
Custom grind.
PM has been sent to SStrokerAce.
Thanks for help
Old Apr 10, 2005 | 07:58 AM
Fahad's Avatar
How much clearance is recommended for exhaust and intake valves??
