Dyno info for my mods
Car- 93 t/a 6speed Formula
36lbs injectors- Venom
Venom 400 Performance Control Module
March Under Drive pulleys
Moroso High-Flow Air Induction Systems
97 ws6 Rear End
Stage 2 Clutch
Flow Master 3 Chamber With No Cat
Do you have a cam? Why the 36lb injectors??
Im geting the motor rebuilt and i want to put a different cam in there being there droping the motor im not sure what type tho. I figured with the injectors the more fuel the more power. As for the cam i need to talk to the guy rebuilding the motor i dont want a cam that will make the car drive poorly somthing more like a mild cam i guess
www.eportworks.com
