195cc or 210cc Any suggestion?
Please its very important, any suggestion will be great..
Deniz
My rotating assembly is top notch quality ,and I spent lots of $$$ so I want to get really strong engine.. The only problem is head choice.. On the AFR's website its written "for highly modified streetcars" for 210cc heads.. Not only race cars.. I'm so confused..
-The 210cc's springs have 220lbs on seat.. Its too much for hydrolic roller camshaft.. Its good for solid roller cam. So I should chose a little less pressure springs. Such as 140-160lbs. I chosed ,but its 1.530"O.D. and titanium retainers are 1.550"O.D. can be there any problem because of this size differences???
BTW guys we just got a set of 210s in and they were only 199cc. What a freaking rip off! We had to send them back out to get re-ported correctly
what about AFR 210's on a 350 or 355?
hydraulic roller of course with a small-ish, high lift cam (comp XE of some sort)
would this work ok?
195-210 are the same casting with different port programs. we paid for the 210 program and got the 199 program. They changed there programs is the word we got. one is a 200 and the other is a 208.
We waited over three months for the heads to come in. You see AFR does NOT have a Propritary LT casting. they have there regular casting welded then Machine them for LT motors. So they wait till they get so many orders then send them off to be welded.
we ordered ours in November and got them in March.
Great heads do not get me wrong but if you really want them to perform get them ported before you put them on the car
BTW I would get a completed set not a bare set. the bare set need SO much taken out it is not funny
If you get the set we did then you have most of the material removed and just need the port reconfigured.OH YEAHH you can have the Hydrolic springs put in at no charge..we did
Good luck all!
They will now
