Back Wrapin
1) I am having trouble with the car always making a loud back wrap when I open it up full throttle or let off the gas in high rpm.
2) It never did this before and now i have added alot of bolt ons and the car has started to make this noise. what can I do. Could it be to much or not enough Gas, air leak, not enough something? Hope someone can help.
3) I do not have the MSD box on yet but am hoping to burn more fuel because you can smell the emtions a little bit at lights or when you turn it off. Smells like it is not burnning the fuel all the way.
LT1 350
edlbrock short headers y pipe
elc water pump
pulleys
MSD 6AL
No cat
3in magnaflow muffler
Chiped MAF
K&N
computer tunned
58MM TB
"chipped" MAF [whatever that means]
computer tuned
Your problem more than likely lies in one or more of those things. Bad tune, or the MAF tables are screwed up. The 58mm is also overkill for that setup.
NEW QUESTION
How hard is it to remove the intake and how long does it take. Do I have to remove both vavle covers, or heads to get it off. what kind if any extra tools i might need to finish this
if you let off at high rpms the engine is choked and you'll hear a popping kind of sound. nothing is wrong, its just that you let out of the throttle and the rpms dont drop instantaneously. it has nothing to do with your mods. i think you have no idea what you're talking about. i hope you have someone helping you do these mods.
you dont need to take the valvecovers or heads off to take off the intake, just make sure you dont get any junk into the intake ports when you scrape off the old gasket. good luck.
It's very easy to do, get yourself a fuel line disconnect tool, unplug each injector (dont worry they've got a number written on the bottom so you dont have to mark em)
unplug your MAP, TPS, IAC, etc from the intake/throttle body, remove the throttle cable (and cruise cable) from the drivers side of the TB.
If you havent already done the TB Bypass mod, nows a good time to do it. There will be two coolant lines on the bottom of the TB, unplug each one and connect them together (93-94)
Remove the 4 bolts that hold on your TB. (This obviously after you've removed your intake elbow/MAF and intake box (or cold air intake))
Some of the intake bolts are studs that require you to remove, or move some brackets. You do NOT need to remove your alternator. Just the one bracket (V shaped) that runs to the first stud on the passanger side of the intake.
Make sure your vac lines are pulled, you'll have one for your HVAC, etc.
After that get at those bolts. Some you can get with a deep well socket, some will take a wrench.
Have fun man, if you have any questions post em up.
scanning the picture in now for the tightening sequence.
LT1's only have 2 coolant sensors. One located in the drivers side cyl. head, the other in the front of the waterpump housing. There are no coolant temp sensors in the Throttle body.
hey man i'm not trying to ruin your day but if you reread your first post it really seems like you have NO clue what you are doing. maybe you just need a typing class because you sound ignorant. sorry to **** you off, i'll go home to my daddy now so he can work on my car.
