LT1 engine removal through bottom pics
Old Apr 17, 2005 | 08:15 AM
Slow ET's Avatar
Default LT1 engine removal through bottom pics
About five hours of time including breaks. Did the all the disassemble myself, so it took a while to figure out what needed to be removed/disconnected. All in all, it was very fun and dirty I might do a little how-to write up on this. I will post an LS1 edition in a few weeks. Enjoy.
Old Apr 17, 2005 | 10:00 AM
Alex94TAGT's Avatar
Jeez -- still have the whole exhaust connected and everything? That's pretty cool. Although, looking at photo #4, I'm not sure how you got that engine out from between the hoist's legs. That *****...
Anyway, it'd be cool if you did a write-up. I'm sure that'd help a lot of people out~
-While on the subject & posting photos, I recently pulled mine out the top. This is, without doubt, the slower method.
Old Apr 17, 2005 | 10:13 AM
Slow ET's Avatar
I knew that question was coming. A well placed jack and cinder block under the vehicle would do the trick. Although i did not use that method. I just extended the hoist to 1/2 ton and moved it to the back and to the side slightly and rolled the dolly sideways out the drivers wheel well.
Old Apr 17, 2005 | 01:37 PM
ex-SS-ve's Avatar
nice. i plan on doing the same thing in a few weeks. hopefully i got access to a lift for it.
Old Apr 19, 2005 | 02:48 AM
disco192's Avatar
Man... i did mine about a month ago... getting it all buttoned up now. I took off the accessory bracket. Didnt know you could leave it all on.... hhmm
Old Apr 19, 2005 | 06:21 AM
METALBEAST's Avatar
Hey Buddy! Good to see you posting again. Mine is coming out from the top this summer so I will DEFINATELY be in contact with you.
Old Apr 19, 2005 | 07:34 AM
transammanv8's Avatar
I'd definitely enjoy a detailed write up. I'm planning on doing the same thing this fall for a cam/k-member/manual rack/etc....install.
