New bottom end? Help parts??
Old Apr 19, 2005 | 04:56 PM
radd's Avatar
Default New bottom end? Help parts??
I need a LT1 gurus' wisdom here.
i need a new bottom end for my lt1 motor
355ci block
what all do i need?
options on the motor
5.7 rod
24cc dome
12cc dome
-5 flat top
6.0
-7cc dome
-5cc flat top
6.125
-5cc flat top
6.2
-6cc flat top
-5cc flat top
What should i go with?
i am cluessless on what i need to order. I would like to go with forged internals. run a little higher compression 11:1?
i plan on spraying a 175 shot if that helps.
Thanks
Joe
Old Apr 19, 2005 | 08:39 PM
TwoFast4Lv's Avatar
not sur eI under stand all the numbers you have here?
Old Apr 19, 2005 | 09:00 PM
radd's Avatar
thats the diffrent pistons availible for my motor i need to know what piston to go with for more compression like 11:1 if it matters. really need some good advice thanks
Old Apr 19, 2005 | 10:57 PM
matt94z's Avatar
I'd go with the dished -5 piston, just get the block decked, and shave a little off the heads to bump your compression.
Old Apr 20, 2005 | 10:35 AM
Mystic97z's Avatar
i'm building a forged 355 right now,
i have 52.5 cc chambers and ordered a -12 reverse dome (i think) piston to give me a 10.2:1 compression, going to deck my heads, and block to get it up to around 10.5:1 hopefully. i wanted a little higher but had problems finding correct pistons for that chamber size. people online say they run 11:1 and higher but call local machine shops and ask them. reverse flow cooling heads help but an lt1 with 11:1 will ping. stay in the 10's. stock 10.5:1 is premo !
Old Apr 20, 2005 | 10:50 AM
N20Dave's Avatar
My old combo had 12.2-1 and I could still run it on 94 pump gas. It took some careful tuning though. Whatever you decide, go with the 6" rod.
Old Apr 20, 2005 | 11:33 AM
radd's Avatar
why 6" rod?
