Streetability
Old Apr 20, 2005 | 04:34 PM
kozak's Avatar
Default Streetability
So i have a question, if i had a LT-1 and i did a whole performance intake, and exaust system and did for instance lloyd elliot LE-1 or 2 heads and matching cam how streetable is the car, noise, gas mileage, driveability.
Old Apr 20, 2005 | 04:53 PM
GhostZ's Avatar
Streetable is dependant on the person. I have full bolt-ons, P&P'd heads/intake, GTP-6 cam, 3200 stall, yada yada and I find it very streetable. Barely any surge...especially after a good tune. It's very loud as I have LT's, no cats and a flowmaster catback.
Gas mileage? BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAafkwfjoei
Yeah....that's the only downside. Actually I'm surprised that I'm still getting fairly decent mileage since I'm still getting close to 300 miles on a tank with mostly freeway driving...some stop and go.
Old Apr 20, 2005 | 04:54 PM
AAron's Avatar
a lot would depend on tune and if it was a auto or stick. stick with stage 1 isnt bad on gas milage or on streetability. but a auto with stage 2 starts to hurt on milage and streetability.
Old Apr 20, 2005 | 05:28 PM
Black97's Avatar
size of injectors?
Old Apr 20, 2005 | 07:07 PM
kozak's Avatar
could i get some super magical like double overdrive gear in the trany, or adjustable air fuel ratio thing-a-ma-gigger. i'm asking because i still need to drive the car occationally very long distances.
Old Apr 20, 2005 | 09:29 PM
screamin94Z's Avatar
WOW! did you add a fuel cell? thats rediculous man! i dont get that now with my stock cam....i'm expecting less with the new cam, hopefully the tune will help me out.
Old Apr 21, 2005 | 10:37 AM
Mystic97z's Avatar
i had the le1 package, i like my stuff aggressive, and personally i wouldn't want any bigger of a cam on a daily driver. my next cam is in the 23x 24x duration, but car is going to be a weekend driver.
i had le2 heads and le1 cam.
6 speed on stock gears.
Old Apr 21, 2005 | 12:38 PM
dhdenney's Avatar
Originally Posted by kozak
could i get some super magical like double overdrive gear in the trany.
It's called the T-56, aka: the 6 speed.
Old Apr 21, 2005 | 05:36 PM
GhostZ's Avatar
Injectors are SVO 30# but will be upgraded again shortly.
I have no idea but for some reason before I put in my Walbro 340 I could only get ~15 gallons or less in the car. After I put it in I can get almost 17.5 gallons in....I know the casing around the stock pump doesn't displace 2 gallons so I don't know WTF happened although I've read other folks experiencing the same thing after dropping their tank and replacing the pump.
Old Apr 21, 2005 | 05:38 PM
kozak's Avatar
what is this "6-speed" you speak of surely it can not be better than an automatic. yeah 6 speed would help alot but i guess it depends on the car you to buy unless you want to spend a **** ton on swaping out an auto for it. i don't know i guess i'm just trying to justify the means.
Old Apr 21, 2005 | 05:50 PM
AAron's Avatar
why thats half the fun my boat now has a t56 fun to drive factor went way up
Old Apr 22, 2005 | 11:29 AM
urbanhunter44's Avatar
wow, I get about 220 +/- 30 (depends on my driving style) on 13.5 gallons. Couldn't ever stuff more than that in there. I'm really surprised you can stuff 4 gallons more than me. That must explain the extra gas mileage.
Old Apr 22, 2005 | 01:07 PM
Coders11's Avatar
For overall streetability you can't beat a T56. If you know your way around under the car you can swap it yourself in about 18 hours. From what I've seen full conversion kits with all necessary parts can be found for around $1000. The only place you might wish you still had an auto is at the track but even then I would rather have a T56 than a 4L60E. A th400 however..... just my .02
Old Apr 22, 2005 | 01:11 PM
Coders11's Avatar
As for gas milage...I usualy am looking at about 2 mustangs and a ricer per gallon...
Old Apr 24, 2005 | 02:57 AM
1bottled93toenvy's Avatar
well my mods are on the bottom...they are not much at all but i can tell u my car is really loud...for me and it doesnt bother me that much..except when im not feeling good or some ****...the gas milage on my car well its bad..it is going to be up to ur taste how much noise u like and what not...also if u haev strict police around ur house. anything is "streetable" if u wanna take it out there..
