Springs
Old Apr 20, 2005 | 06:19 PM
Black97's Avatar
Default Springs
What is the numbers?
comp cam: 978: Size?? (O.D) How much lbs pressure on seat??? , max lift??
comp cam: 987: Size?? (O.D) How much lbs pressure on seat??? , max lift??
Which spring is better for a 210cc AFR Heads with 236-245 , 575/575 ,114lsa hydrolic roller cam??? Or should I go with 1.530 O.D AFR's flat tappet springs??
any suggestion will help me..
thanks
Old Apr 21, 2005 | 01:49 AM
Formula94's Avatar
Get the bee hive springs. They handle more lift than the 987s and are much more efficient. Those are the ones I am going to when I get my heads done.
Old Apr 21, 2005 | 07:25 PM
Black97's Avatar
No one knows how much pressure on the seat and max lift of these 2 springs???
