stock cube cams
Old Apr 24, 2005 | 10:28 PM
project98LS1's Avatar
Default stock cube cams
hey guys im lookin for max performance stock headed/cube cams. would you all mind postin up your set-ups and what they put down along with full specs on the cam. I need somethin big that I can use cam only for a while before purchasing heads. thanx
Old Apr 25, 2005 | 12:37 AM
Jordan57's Avatar
ummm you have an ls1....wrong section. unless you have an lt1 thats hiding somwhere.....in which case disregard that.
Old Apr 25, 2005 | 02:09 PM
lt1s not in sig
Old Apr 25, 2005 | 07:31 PM
No one here has a cam only set-up or remembers what theirs put down on the dyno?
Old Apr 26, 2005 | 04:54 AM
DietCoke's Avatar
Went 11.9@116 with heads and a 233/239 cam and an auto. Mid 12s cam only. The cam's for sale as well.
Old Apr 26, 2005 | 05:49 AM
Snow Dog's Avatar
there was another thread not to long ago about this. many different cams were listed. most of the max effort cams put down 340-380 depending on other mods and drivetrain setup. couple of the biggest would be the comp 306 cam and the GM 847 cam. you could also go for a Lloyd elliot stage 2 or 3 cam. all these cams really need heads to go along with them, but they can work with stock heads. once you put heads on there though expect anywhere from 380 to 420 at the wheels. again depending on everything else the car has too.
Old Apr 28, 2005 | 09:07 PM
Does anyone have any #'s or know of anyone running CMS nitrous cam 239/248 115 or similar?
Old Apr 29, 2005 | 03:43 PM
Formula94's Avatar
I've got the cc306. 230/244 .545/.576 (w/1.6 rockers) 112lsa. Power and times in sig.
