spring suggestion
Old Apr 28, 2005 | 11:21 PM
Aries's Avatar
Default spring suggestion
need a suggestion on springs to use on a .620+ lift cam with LT1 heads that use stock seats. ideas? recommendations?
Old Apr 29, 2005 | 05:28 AM
blackdogz's Avatar
Your best bet is to give Comp cams a call - http://www.compcams.com
Old Apr 29, 2005 | 10:14 AM
Crazyz28's Avatar
.620+? k-800's which can handle up to .700. They also don't require machining the head, either.
Old Apr 29, 2005 | 11:57 AM
rockcamaro97's Avatar
Aries, I used a spring from a local valvetrain parts company that is for solid and hyd rollers that will support .675 lift. Contact me if you would like more info. With the stock spring seats you can probably get away with not machining as the spring is 1.437 but with my comp spring seats I used a little clearancing was required.
Matt
