Engine Build up question
1) What is the torqe spec for apr head studs ?? I lost my sheet
2) Is there any type of seal that goes under the fiting that the oil filter screws too. The metal part that has its own little screen and is held in by 2 bolts. I did not take it a part so i was unsure about this.
Thanks for your help
Micah
On a side note, I think i have found the OPTI SPARK KILLER.
The cam is able to move in and out, (A LITTLE) i think that when this play gets to be exccessive, That the dowel pin from the cam starts pushing in on the opti , thus pushing the rotor into the cap and causing a failure.
2) There is no gasket on the oil filter adapter. Just bolt it up.
Micah
