LT1 problems
Got the car running, had air in the lines from install (pulled K-member)... drove it a little (very slowly) and the brakes did nothing. I had a leak and air in the lines. Prolly ran the master cylinder dry.
Then bled the system properly.
Now it holds weird pressure (power brakes are working). The pedal falls pretty fast. If you apply firm pressure, then it holds... if its weak pressure, then it goes straight to the floor. Sometimes it will also lock up and not release brake pressure from the calipers until I push the pedal slowly all the way to the floor and it will release it.
Im swapping the master tonight. Ill keep you posted.
Did you bleed the ABS unit? cycle the key several times to prime the pump. Then open the bleeder on the pump for the rear, press pedal to the floor and hold, close bleeder, let pedal up, open bleeder, pedal down, close bleeder, pedal up. Repeat that on both bleeders with the key on.
After that bleed all 4 wheels again with the car running or key on starting at the right rear, then left rear, then right front then left front. if STILL it's not right then I suppose the MC could be bypassing and causing your issue.
