Intake manifold
I got an intake manifold off ebay that I am going to port to 58mm, and also port the runners in. I picked it up for 60 bucks (with shipping) Its painted up and looks cool......so whate ever. Here is my problem. This intake manifold is off a 1993 LT1. There is a gap on the top of 94-97 LT1 manifolds for the fuel rails to connect to the opposite side of the manifold. This manifold is missing this gap. Will this manifold work on my 1995 Z-28?
Your fuel rails aren't going to bolt up to it. The bolt holes are rail positions are the same, but they won't sit down far enough to bolt in/get the injectors in the bungs because of the front crossover.
You could converto to a set of 92-93 fuel rails, which would only take a bit of minor work to the fuel lines to move the connection point to the driver side of the manifold, or buy the proper year specific manifold you need.
