Aftermarket Intake Manifold
I have had good luck with Ultra black and a 24 hour sitting time.
If you start it to early it just sucks the sealant into the engine and you have a leak
Changing the intake to another will not fix the issue. It is a well know very common problem. I have my first one fixed under warranty with 17K miles...
If the intake is warped a machine shop could machine it true again for a lot less than the custom work you are going to need because there are no readily available intakes. If there were they would be the same aluminum you are blaming for the warping problem you believe you have.
Matt
In fact, here is a link for a guy who fixed his intake manifold, who also put heat tape on his pipe as well...
http://www.geocities.com/MotorCity/Downs/4013/ol.html
