Got a formula today! Need a little help.
Dustin
http://www.f-body.org/tech/tech.htm#T56
I want to get rid of this 110 mph gauge cluster and swap in the 150, I see many on ebay for cheap. Is that a hard thing to do? Why did they do the 110 rather than the 150? Also the ABS INOP light is on I imagine that is because of the gears. I figured an easier way to know my gear size is compare my speedo's reading to how fast I am really going and do some math knowing that stock gears are 2.73.Dustin
At least that's the way I understand it.
Get some chalk and do like a poster above suggested, that will tell you alot. Or get a car to pace you and get your actual speed, then compare it to your tachometer.
In your one to one gear (4th in your case) bring your car to 70 MPH, pacing your friend. A cell phone is handy, have him tell you when you're doing 70. Now look at your tachometer, if your tach reads 4100 RPM approximately, then you have 4.10s.
93 T-56s go by gearing, the 2.73s had a different geared six speed than a 3.23 car, I believe the RPO codes are M28 for the 2.73 six speed and M29 for the 3.23 six speed. Evidently 3.23 "wide ratio" T-56s are geared exactly like a Corvette Z06. I think Dakota digital makes a box for reprogramming the speedo
Dustin
Probably because they wouldnt have Z-rated tires option which was QLC if they had the 115 speedo
http://www.jegs.com//cgi-bin/ncommer...36&prmenbr=361
Speedo correction options are limited. Other then the above mentioned SLP Speedo Recalibration Box (serach Ebay, they pop up from time to time) and the cyberdyne (never heard of that one) there's also the Dakota Digital SGI-5 box which should work too.
If you're planning on swapping a 150 MPH speedometer/cluster into the car, remember the following: If it's another 93 cluster you're putting in, simply put the cluster in. If it's a 94-97 cluster, you need to remove the Tachometer filter for the tach to work correctly, OR, put in an aftermarket ignition box which will send it's own signal to the tach. Tach Filter Location
Oh, and 93's are just plain faster than 94-97 LT1's.
, i have one of those arrest me red ones too
Nah I agree
