383 LT1 stock heads with nitrous?
Why are you building a 383? Did you blow the current setup? If all you're looking at is a 150-200 shot, why not just upgrade the pistons and maybe rods on the current setup? That would save quite a bit of money to start doing things right. You could spray 200 all day long on the stock crank and forged pistons/rods and you'd have the $$$ to have your heads ported and a cam to match which would put down much better results than a choked 383.
A little more info on the current setup and why you're going to spend the money on a 383 but leave the heads stock.
Good luck with that. I'd be suprised if it made over 400rw with a 150 shot. There isnt enough flow there to support that kind of air/exhaust flow.
Again I do plan on getting my heads ported later on, but I am anxious to get the power now, and figured I could do so with the direct port system since it would be cheaper.
So yes, a stock displacement motor with worked heads and matched cam has a decent chance of outperforming a bolt-on 383 with stock heads.
What you're not realizing is that the power comes from the heads. There are 350's that put down more HP than 383's due to their heads/cam setup. Strokers help....more with torque but you aren't going to make near the power if you don't invest wisely in heads.
And a fogger setup would be far less expensive than a direct port setup.
