Is the Steam pipe on the heads necessary?
Old Jun 9, 2005 | 11:33 PM
Not a 350's Avatar
Default Is the Steam pipe on the heads necessary?
Is the steam pipe on the back of the heads absolutely necessary? What would be the consequences of not running it?
Thanks,
-Aaron
Old Jun 10, 2005 | 12:30 AM
buffman's Avatar
hmm trapped steam pockets in your head = overheating = no no = bad idea. It's there for a reason, stop messing w/ it..
Matt
Old Jun 10, 2005 | 12:51 AM
blind527's Avatar
I believe if you do the throttle body bypass, you put the feed hose into the steam pipe anyways, gives you a few extra *lost* ponies
Old Jun 10, 2005 | 11:50 AM
RealQuick's Avatar
Thanks,
-Aaron
Steam pipes? Never heard of them. Are you referring to the coolant crossover pipes? The coolant goes from one head to the other due to having a dry intake.
Old Jun 10, 2005 | 02:53 PM
buffman's Avatar
that's what he's talking about, but I'm sure he's prolly refering to doing the Throttle Body bypasss??????????
Old Jun 10, 2005 | 03:00 PM
RealQuick's Avatar
With him calling them steam pipes, I dont think its safe to assume anything
Old Jun 10, 2005 | 03:29 PM
CatchinZs's Avatar
http://shbox.com/1/93-94_hoses.jpg
You'll see in the above diagram that you are all talking about the same thing.
It is technically a coolant crossover but I've seen numerous people refer to the long part that runs up to the TB as the steam pipe.
I don't think I'd take if off just for the sake of taking it off.
Old Jun 10, 2005 | 03:54 PM
LTSpeed's Avatar
Those are called steam pipes by GM and they are critical due the the LT1's reverse flow cooling system. Without them, you run a much higher risk of warping your heads--especially if you do sustained high speed driving, like on a road course.
Old Jun 10, 2005 | 07:05 PM
Not a 350's Avatar
Yeah, I'm calling them steam pipes because that is what they are referred to on the shbox.com website. I'll definately leave them on the car, thanks for the advice everyone!
-Aaron
Old Jun 10, 2005 | 08:35 PM
HBHRacing's Avatar
yes, they are a steam pipe. It's common in all motor but with the LT1 reverse cooling number 7 and 8 pistions can get REALLY hot and the coolant can boil in the heads. The steam pockets will heat and if traped cause lots of issues with heat in the heads, combution chambers etc etc. The steam pipes allow the steam somewhere to go and bleed off. I would never ever ever remove that function. some people with big time motors actualy imporve on the design with a bigger SS line to help aid in the steam removal.
Old Jun 12, 2005 | 11:05 AM
SSRZ28's Avatar
so our heads are dry manifolds. no coolant in em? did this start in 93?
Old Jun 12, 2005 | 11:36 AM
HBHRacing's Avatar
no, the manifolds are dry manifolds. Because of the reverse cooling, the heads get the coolant first but numbers 7 and 8 can get very very hot and you can get nucleat (sp) boiling which is why the steam tube is on the back of the heads.
Old Jun 12, 2005 | 08:43 PM
SSRZ28's Avatar
so no coolant is in the manifolds right? i can take it off with out draining the coolant.
Old Jun 12, 2005 | 11:00 PM
buffman's Avatar
correct our intake manifolds contain no coolant
