throttle position sensor question?
Old Jun 12, 2005 | 10:33 PM
94camarof1's Avatar
Default throttle position sensor question?
where's the output voltage lead on the TPS of a LT1?
trying to install ZEX
Old Jun 12, 2005 | 10:35 PM
Brett95z's Avatar
its the white wire isnt it?
Old Jun 12, 2005 | 10:37 PM
94camarof1's Avatar
Not sure, you think it is?
Old Jun 13, 2005 | 10:13 AM
HBHRacing's Avatar
should be Dark blue
PS, there is no white on the TPS
Dark blue = signal in to the PCM
Black = sensor Ground from PCM
Grey = 5 volt ref from PCM
