Which Timing Chain To Use???
Old Jun 13, 2005 | 01:45 PM
asudecat's Avatar
Default Which Timing Chain To Use???
Im not sure on which timing chain to use. Some people say dont use the heavy duty. Would I go with Cloye's if I had an electric water pump??
thanks
Old Jun 13, 2005 | 08:51 PM
asudecat's Avatar
No one know's this or what?
Help
Old Jun 13, 2005 | 09:45 PM
Brett95z's Avatar
I use the stock timing chain ( new of course ) With my 306. It sees 6000+ almost daily
Old Jun 14, 2005 | 07:09 AM
contraststriker's Avatar
Go with a Summit true double roller. Very strong and only $42.
Old Jun 14, 2005 | 09:24 AM
LT1Factor's Avatar
I got the LT4 Extreme Timing Set when I did my LT4 hot cam kit, handles the load well
Old Jun 14, 2005 | 11:01 AM
Smokinlt1's Avatar
A lot depends on what year car you have I believe. I know on nonvented optis you really dont' have many choices. I went with the Lunati kit from Summit back when it was $109, now I think they're selling them for around $200. Not sure though.
Old Jun 14, 2005 | 11:25 AM
flyinZ's Avatar
If you have a vented Opti, Id check out Cloyes, or Rollmaster. If not, then a GM or Lunati will have to be it.
Old Jun 14, 2005 | 12:19 PM
Cloyes and Summit both perform about the same, so if you have a vented opti go for whichever is cheaper. Do NOT get an LT4 extreme timing chain kit, it's a huge rip off.
Old Jun 14, 2005 | 01:02 PM
asudecat's Avatar
where can you get a vented opti?
Old Jun 14, 2005 | 03:06 PM
Brett95z's Avatar
What year is your car? You may already have one. 95-97 got them.
Old Jun 14, 2005 | 03:27 PM
asudecat's Avatar
haha ok then I guess I do
96 Formula
thanks
Old Jun 14, 2005 | 05:32 PM
Y2kHawk05's Avatar
So, for my 93 Z, can the Double Roller be used for daily street driving? And why is the vented opti necessary?
One more question. What is the easiest & best way to lift the engine with only have floor jacks?
While having the engine broken down, I want to replace oil pan gasket, plus any and all that I can. Right now, getting the engine raised with limited tools (2 floor jacks) seems to be the obstacle.
Old Jun 14, 2005 | 05:55 PM
Jordan57's Avatar
Not sure about jacking up the motor with stands...I used a pump jack. The vented opti isnt necessary, just less suceptible(sp?) to water condensation and what not. A few mods to your timing cover and cam dowel pin are needed to get it to fit. But it's worth it bc a vented opti is a lot less than a non-vented opti. Only 239 from Jason Cromer samtaylor.com....shipped. Yes the double roller can be used. It's more durable. Don't go LT4 extreme duty..it's overpriced imho. Cloyes has worked well for me.
Old Jun 15, 2005 | 05:21 AM
You MUST have the vented opti if you're going to use the more inexpensive Cloyes or Summit double rollers. Non-vented optisparks require a longer pin from the camshaft or something so they can't use the aforementioned double roller timing chains.
Old Jun 15, 2005 | 08:09 AM
Brett95z's Avatar
And i was under the impression that 93/94 timing covers are different than 95-97's. You also MUST use an electric water pump with a double roller. The drive splines on the water pump arent long enough to extend over the dual chains. You will most likely also have to clearance the inside of your timing cover.
I see the double roller as a bit of overkill, when many many people just use a stock replacement and are fine.
Old Jun 15, 2005 | 11:58 AM
Y2kHawk05's Avatar
Wow! Lots of great information. Thanks guys. 93 is definitely an oddball year for the LT1's. Still a speed density piece of junk in my opinion. I am seriously considering different options and not entirely sure on anything yet. You all have been a great help and I am sure I will have more questions.
Thanks again.
Old Jun 15, 2005 | 12:32 PM
asudecat's Avatar
so will this one be good enough for my 383 lt4 with electric water Pump?
http://store.summitracing.com/defaul...=egnsearch.asp
or is there one better for me. or something similar but better price?
Old Jun 15, 2005 | 01:42 PM
asudecat's Avatar
Hail nevermind. that wont work. The only ones on summitracing.com are the cloyes for 349 and the lt4 ext duty 245. Where are the cheap ones at??
Old Jun 15, 2005 | 01:58 PM
on that link you posted, 4th one up from the bottom will work!
" SUM-G6601 Summit True Roller Timing Sets
Timing Chain, Double Roller, Steel Sprockets, Chevy Small Block V8/ 90 Degree V6, Set "
Old Jun 15, 2005 | 03:10 PM
Pampered-Z's Avatar
I did the conversion on my 93 to run a double roller chain and elec. water pump. here is a link with goog info.
http://para.noid.org/~muttvette/opti.html
