LT4 conversion questions
I am wanting 400-450 hp.
Guidlines:
This car has to be able to be a daily driver.
Budget $2,500
I have found the complete LT4 conversion kit from GM for $2,100.00 (I can get for cost)
I do plan on adding 100 shot of Nitrous, but NOT right away.
For my goal of 400-450 hp (without NOS and or Forced induction), and a $2,500 budget what would you prefer? I would rather only go with a Head,Cam, intake package to achieve this, yet still be fully streetable. (FYI, I plan on Headers, cat back is on the way)
Is my stock fuel system going to struggle? new pump, injectors? What size? where to get?
What size throttle body to go with? TB spacer worth the $?
The car is a 96 SS car, meaning it has the intake to accomodate the Hood scoop, is there a better alternative?
I will need to buy a PCM tuner i was thinking HP tuners. (I have laptop) any suggestions?
I really am trying to stay away from Superchargers, or turbo right now.. Definately may go with that at a later time.
Thanks for the Info guys! much appreciated!
as for you goals though. that LT4 package requires exhaust changes before you reach that power level. if and only if the fuel system and ignition system can hanlde it will they be fine for your goals. you need to make sure all of that is in tip top shape before throwing mods at the car. no sense in spending thousands on heads and cam if your fule pump is dying. the car wont make any power then. now i am assuming you mean 400-450 crank horse power, not rear wheel right? if so then the LT4 conversion will get you there if you have all the bolts ons too. substitute a bigger cam in there and you will be set. there are many choices out there that will fit your needs.
I am willing to go with a bigger cam than the GM hot cam, if it can handle daily driving criteria. What cam is recomended? expected price? specs?
I was thinking about the Elliot Portworks LT1-LE3 package $1,800
Includes:
Larger valve seats in heads
2.05/1.60 valves
comp bee hive springs
titanium retainers & 10 degree locks
208 CC intake port
milling
cleaning
assembly
flow rates 275/195
Ready to be bolted on
Says with the supporting mods (36/42lb injectors 58mm tb and good tuning) should see 410-430 RWHP.
Does this sound right? i have heard people talk about him.. he does really good work.
And is my fuel system gonna be over-loaded? The car only as 11,000 miles on it. (1996 ss 6-speed)
The fuel system shouldnt be worn out. what other mods for sure would i need for this?
Includes:
2.05/1.60 valves
208 CC intake port
milling
cleaning
assembly
flow rates 275/195
What type of cam would work well with these heads?? And is my fuel system gonna be over-loaded? The car only as 11,00 miles on it. (1996 ss 6-speed)
