poor acceleration under load... spark missing?
Some exposition first: SPEC stage 3, 230/242 cam, PCMforLess tuning, Taylor 8mm wires w/ngk-tr55 plugs .050 gap.
When I give it gas, it stumbles and basically accelerates like crap up until around 2000 rpm where it abruptly changes to the acceleration you would expect, smooth and pulling. I say abrupt because it's definitely NOT just entering the cam's effective rpm range. It's as if under load it's missing. When I really give it gas, normally I can pull it out of the "bogging" phase. Do I need an MSD or equivalent spark booster? Fuel pressure checks out at 45 psi, so that doesn't seem to be the problem. IF spark is the problem, why would it be weak? All components are brand new. Notice that the higher gears are nearly useless, as they're under load most all the time and just make the car shudder as it misses. Any ideas???
You really should check 02s and map and maf those are the most common stumbler causers besides opti...But yeah I havent figured mine out yet
Have you scanned it for any codes?
