Same miss on the dyno
Old Jun 23, 2005 | 09:17 AM
dhdenney's Avatar
Default Same miss on the dyno
Well, I thought I had it fixed but only improved it marginally. In a nutshell, it's missing on the dyno. It's not plugs cuz cylinders 5-8 are rich and 1-4 are fine, done this on 3 different brands. It's not the coils on my Delteq cuz a couple of the coils share good and bad cylinders (eg: 4 and 7 are on the same coil with 4 fine and 7 rich). I don't think it's wires cuz they're not burned and I wouldn't think a cheap wire would cause such a miss. Voltage is 11.8 under load on the coils so I am gonna try to hotwire them to the alternator to boost voltage to 13+ and see if that doesn't help. All that's really left is optical. Don't think it's fuel cuz my AFR is completely flat under all tuning conditions. If it's 13.0:1, it's flat and if it's 12.2:1 it's flat. Thoughts?
Old Jun 23, 2005 | 09:34 PM
dhdenney's Avatar
ttttttttttt
Old Jun 24, 2005 | 05:20 AM
rebersole2's Avatar
Replace the wires anyway. A cheap wire can't cause a miss, any wire can cause a miss, especially if it is the one's you put together yourself. I have a box of bad wires that look brand new. If it is not the wires, go after the ignition. You must change parts until you find the answer.
Old Jun 24, 2005 | 09:14 AM
dhdenney's Avatar
Well I guess you're right. I just hate spending money and not solving anything. BTW, I have friend that lives in Lincoln Co. Mississippi. If I remember, Amite is just south of Kentwood right?
Old Jun 24, 2005 | 02:13 PM
dhdenney's Avatar
Tried hotwiring the coils to the alternater for a voltage boost. Still misses. I need to check and see if the back cylinders are burning any cleaner though.
